Mini Fuel Injection
DSwanson
Did all the last Rover Minis use fuel injection? Is it adaptable to older Minis and other A-series powered vehicles? Does the computer just control the fuel injection or also the ignition timing?
aeronca65t
Some of the last Rover-Minis were fuel injected, but I don't know any details about the sytem that was used.
But, if you are interested in a home-brew fuel injection system, you may wish to look at the "Megasquirt" system. It's cheap to build and has lots of free software online, plus good tech support via a user's group.
https://www.megasquirt.info/
ThomP
It's a full control system, complete with different distributor and crank timing sensor. Actually there are two types: A single point and a dual point injection system. The dual is the newer of the two. I think Fuel Injection showed up on Minis in 1993 or '94.
Keith Calver has experimented with FI for performance. In spite of the improvements in low end torque, he abandon the project, because little was known (or could be discovered) about the Rover controller.
I have seen impressive dyno curves showing 100% more HP in the low RPM range. The top end of the curve was "only" about 10% better than a carburated car.
Mini1000
One thing that I have noticed is that people generally don't prefer the spi as much as the mpi engines...in fact I have seen many folks with spi engines go back to carburation...MiniMania sells an injection-to-carburation conversion kit. /ubbthreads/images/graemlins/grin.gif
pbraun
I have a 91, German made mini, first year of FI, I thought. Perhaps 92. Single point.
DSwanson
With all the newer Minis coming over here to the states, and knowing how most people like twin carbs better, I thought a used complete stock FI system would be cheap and if it were easy to retrofit I might try to put one on my '62 A.H. Sprite. While not a "performance" system, I would think it should be better (horse power and economy) then a stock twin carb setup. With multiple sensors & a different dist. I think it would be much more of an undertaking then I would want to perform.
Morris
Hello all,
I am new to the forum, and this is a very exciting converstation for me...
I am working on a retrofit fuel injection kit for LBC's. My test bed (read my car) is a '79 Midget, but I intend to eventually roll out kits for all the popular makes and engines.
My goals are to create a kit that: a person with modest mechanicin' skills could install in a weekend; will improve fuel economy and emissions; will improve reliability; and will cost several hunderd US$ less than the kit Moss is offering for the MGB. While I expect that there will be a modest performance gain, I doubt it will be enough to satisfy real power junkies.
Anywho, I will be looking to the community for a lot of support for this project over the next few years so I look forward to chatting with you all a lot more about this topic.
Thanks,
Morris
Ps. Yes, Morris is my real first name.
pbraun
Cool, Morris! Welcome to the forum! I am sure many folks will be interested in reading about your progress in your project, and also willing and able to help out with advise and experience.
Best regards,
bmwracr
New guy here. I've got a single point Mini, and no info on the fuel injection system. I've got Haynes, but it is, in a word, pitiful. Where can I find a description of the system, operation, adjustments, and in general just what should connect to what?
dklawson
BMWracr, your car/engine is so "late" that there won't be many resources for it in the U.S. Your best bet will be to post a message like this on the Mini Mania / Mini Spares web site and get someone in the U.K. to identify a text that will help you. Mini Spares or Mini Sport may have books better suited to your needs than any U.S. source.
bmwracr
Thanks for the response. I'll keep looking . . . or I DO have this twin choke 40mm Mikuni side draft sitting in the basement. . .
dklawson
BMWracr, I posted your question at:
https://www.theminiforum.co.uk/ which is another forum I frequent.
The response there was that the SPI system is not tuneable so there isn't much information about it presented in any of the manuals. The Rover manual apparently goes into more detail about how the system works, but it appears to be an auto-tuning system so all you can do is buy a scanner to troubleshoot it and replace any parts that are defective.
Visit TheMiniForum sometime. Unlike the Mini Mania / Mini Spares forum, there are a lot more people who own late model Minis who should be able to help you with the SPI.
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
C 1275 fuel injected mini engine in a sprite? Spridgets 7
K McLaren: Fiat/Mini Type Fuel Saver? Triumph 1
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
TomMull For Sale 10 inch Mini Rims (2) Other British Classifieds 1
Basil Mini Pick Up Spotted 8
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
pbraun Alex Moulton's special Mini Moke for sale Other British Cars 0
C Autocrossing a classic Mini problems Other British Cars 2
Sherlock Mini Cooper patina Spotted 0
Basil The Queen in a Mini! Spotted 3
GB1 Classic Mini Mayfair Auto Other British Cars 1
Baz 2012 Mini CEL - Now it begins........ British Motor Corp 0
J 2006 Mini Cooper S British Motor Corp 6
N Classic Mini Engine Identification British Motor Corp 6
P Classic Mini advise British Motor Corp 1
D Possible Mini Gauges? British Motor Corp 6
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
tr6nitjulius Mini @CCBCC All British Meet 7/14/19 British Motor Corp 0
JPSmit Green Mini - with halo headlights Spotted 0
Alfred E. Neuman Austin Mini Breadvan Spotted 0
AngliaGT Real Mini Spotted 0
S TR2/3/3A Tr3/Mini Girl Triumph 0
T Will Mini Spin on Adaptor work on Bug Eye? Spridgets 10
Bob Claffie Ultimate Mini British Motor Corp 3
coldplugs Jensen Interceptor & a Mini Spotted 8
pbraun Mini Meet East 2017 British Motor Corp 4
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
Basil Mini? Spotted 5
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
JPSmit Mini + iphone question Other Cars 3
Chuck9482912 Mini Spare Tire Austin Healey 9
B Mini Windscreen Wiper Parking British Motor Corp 3
3798j AACA Museum's Micro & Mini Exhibit Other Cars 1
J Motorcycle oil for Mini, based on shared oil British Motor Corp 4
DrEntropy Mini brake conundrum British Motor Corp 12
Boink 1973 Marcos MINI Spotted 1
bugedd Mini Metro Turbo setup Spridgets 12
6 Mini in Groveport Spotted 0
Steve Mini photos... British Motor Corp 6
H 1961 Mini MKI speedometer Housing pod & dashboard British Motor Corp 0
H 1958-1961 Austin Mini 850 speedometer housing pod British Motor Corp 3
J Funny noise in my mini British Motor Corp 12
Steve A Mini that is not what they are saying it is British Motor Corp 18
Mickey Richaud Mini Midas? British Motor Corp 1
Mickey Richaud Mini Midas? Other British Cars 4
R Tyres for Mini Cooper British Motor Corp 7
