Milky White Gooey Color in Oil
dmorris1
Hi everyone, Just replaced the head gasket and went for a short drive and after setting for a while checked oil dipstick and notice a white gooey substance mixed with the oil. I also removed the valve cap and notice water dripping. There is no white smoke coming out of exhaust. What is going on? I have a 1967 BJ8.
David
pkmh
My first Healey which was sitting for a while, developed a white yogurt film or gooey substance under the valve cover cap. I also drained the oil to reveal a sludge in the oil which at that time, could of been old oil, but having no gooey appearance. My situation was a car that was sitting for some time with old oil in the engine.
Given your situation and based on the information provided above, I would also check your coolant to see if any oil is present. I would then probably drain the oil and inspect. If evidence of water is present, you still have a seepage issue. Did you have this problem before replacing your head gasket?
bob hughes
Sounds like water in the oil to me - mayonnaise they call it. I have experienced it in my first Healey under the rocker cover but not in the sump.
Could be a number of causes - head gasket gone, or the oil-way that passes through the water jacket of the block has gone porous. Since it did not occur before you changed the gasket ( presumed) then I would look at the head gasket. - That is the cheapest and easiest to fix.
Best of luck
:cheers:
Deleted member 8987
Mayonnaise or Milkshake. Caused by homogenizing the oil and water through the oil pump.
Takes a goodly bit to do that.
Cracked head, cracked block, defective new head gasket.
Pull the plugs, fill radiator, pressurize radiator at cap with proper tester, not exceeding manufacturer's specifications, leave it sit like that for 5-10 minutes. See if the gauge on the tester moves.
Then, using an assistant, and OUTSIDE, have assistant watch the plug holes, NOT in line with them, and crank it for a couple of revs only. Have him tell you which hole the hater shot out of. Give you an idea where to look. If no oil, and no steam-blasted-white plugs, lower end, possibly a crack, don't know of any coolant jacket gallery plugs in the crankcase, but never know...
Deleted member 8987
If it is head gasket, caused by studs, bad gasket, warped head or whatever, when you pull the head off, use at lease a half can of weasel pee to flush down the cylinder walls, rings, rotate engine one full turn and do it again. The water sitting there while you decide which vendor has the best prices on parts you need will rust things quickly.
bob hughes
Bear in mind the head cylinder studs MUST ALWAYS be replaced when replacing the head gaskets as they stretch and no longer shows the correct torque when torquing. Don't ask me how I know
That is a new one on me. I have never renewed the cylinder head studs, nor the crankshaft and mains bearings bolts on any of my cars and I have not experienced any problems.
:cheers:
Keith_M
:cheers:
New for me too Bob. I don't think it's common practice, but I'm no expert.
Keoke
RAC68
The last and only time I re-torqued my head bolts was 2 years ago after re-bushed my valve train. Prior to that, I had changed my head gasket in 1968 after the car was stolen for a joy ride by a local and the head gasket was blown. Although I had never given head-bolt stretch much thought, I found when reinstalling my valve train, one head bolt had stretched sufficiently to cause a problem. A few run of a file provided sufficient clearance to properly install the train without concern. However, although I had heard of head bolt stretch, I never thought it could really happen to these hardened steel bolts. I stand corrected.
Ray (64BJ8P1)
bdcvg
If I remember correctly the O.P. had a post not long ago about installing a non stock grind camshaft so I assumed We are looking at a total rebuild which as long as the head was decked during machining probably means bad gasket or a crack. The new head bolts/reuse is usually dependent on how many times the used bolts have been torqued.
Johnny
Hi David, a little more information might be helpful before tearing into this project. Such as, what caused you to replace the head gasket? How long has the car sat since last driven a lot? What else has been done to the car?
TR4 Milky oil? Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
M Old English White Paint Code for early BE Spridgets 1
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
S TR2/3/3A de-bossed sections that are painted white Triumph 2
Jim_Stevens TR2/3/3A Pearl White not what I expected Triumph 22
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
Jim_Stevens TR2/3/3A Nimbus White? Triumph 15
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
ckeithjordan TR2/3/3A Apple Hydraulics vs White Post Restoration Triumph 13
71TR6 TR2/3/3A Modern paint code for 1959 Triumph #19 Pearl White Triumph 20
TomMull White Mold Restoration & Tools 3
D For Sale TR3A-B Side curtain set - white Triumph Classifieds 1
Jim_Gruber Paint Codes for Olde English White Spridgets 11
5 Old English White Bugeye on E-Bay Spridgets 10
M Spotted: white Healey 100...in Maine Austin Healey 2
M Mystery white smoke Spridgets 11
T TR2/3/3A For sale: New side curtains, white, for later tr3a Triumph 8
H Mk.II ratty white one near Ontario,CA--I could investigate further Jaguar 1
B Recommendation for Healey Blue and Old English White Paint Austin Healey 15
S Green/white BN7 Chequered Flag Austin Healey 7
F White smoke and I cant figure it out. Spridgets 17
M_Pied_Lourd TR2/3/3A Modern Paint Reference Numbers Spa White Triumph 7
S bj8 white wire loop Austin Healey 2
TRMark Spa White Paint Triumph 5
T Cleaning a White Interior Triumph 0
RAC68 Old English White Touch-up Paint Austin Healey 8
T TR4/4A White wire question on TR4A A-type wiring Triumph 2
GlennG Primer Color under Spa White Triumph 3
Darrell_Walker tail light reflectors -- chrome or white? Triumph 7
S White foam in the radiator?? Triumph 17
AngliaGT Newer White Ferrari Spotted 0
R Red, white and tan covert tops aftermarket 60's? Triumph 11
S MGB White wire wheels on an MGB? MG 15
regularman White letter tire dilemma Spridgets 11
mountainman White Walls or Not? Triumph 23
jlaird Twice, white MGB Spotted 0
V Lovingston/Nelson Co. VA white MGB Spotted 0
D about a 73 GT6, white Spotted 14
aeronca65t Vanna White Other Cars 0
M Old English White: BN2 vs New Mini Austin Healey 2
D White 69 E-type 2+2 Spotted 0
newmexTR3 TR2/3/3A NYC White TR3A on Craigslist Triumph 7
pjsmetana Spitfire Spitfire, Wire Wheels, White Wall Tires... Triumph 26
J White Crown for Window Crank? Austin Healey 4
Marvin Gruber Ivory white paint formula Austin Healey 8
B 74 XKE blowing white smoke. Jaguar 14
