I'm TRYING to purchase a nice, completely rust-free 78 Midget. My wife's only requests--after wrestling for two years with a hopeless TR6--are that I start it and drive it home. Doing so requires a new starter and replacing the clutch hydraulics. With the new starter, she fires up and purrs. The clutch is still a problem, though...
The current owner and I have replaced every hydraulic component and bled the system to get a nice firm pedal and about 1/4 of movement between the cylinder and the transmission housing. But, try to put her into gear and she grinds so bad you have to stop trying. So, it won't go into gear. For the record, it has been sitting for several months...
I'm assuming three possibilities. Either (1) the system is not fully bled (i.e., we need more than 1/4" of travel at the housing), (2) there is an adjustment we are failing to make on the post-hydraulic (i.e., mechanical) end of the clutch, or (3) the plate is stuck inside the tranny. FYI, assumption 3 sounds too hard to fix....please tell me it's 1 or 2!!!
In either case, does anyone have any recommendations about how to troubleshoot and fix this one so I can give her a new home? I appreciate any information as I'm at my wit’s end!
