77 Midget, Does anybody know what part of the electrical system would cause the starter motor to run when the hand brake is applied? I have disconnected the switch under the seat but would like to have everything working properly. After pulling the motor and trans for trans rebuild this weird thing happened. I found that the switch wire was under the seat rail and moved that and found no damage. I could start the car normally with the handbrake off and all was well, when I applied the hand brake th starter motor would engage. If trying to start the car with the hand brake applied then the starter would keep running. Turn the iginition switch on and apply the brake and the starter goes!!! What gives?
Also I have replaced rear springs and bushings and inspected all mounting surfaces etc. (no rust on the car) but it still sags in the rear noticablely. The passenger side much more.
It is the same as it was with the original springs just a little better with the bushings renewed. No apparent damage or body bending (34k miles and no wreckage) HELP please if you know anything. Thanks Ed
P.S. Looking for a good fm radio that will fit, does not have to be original but that would be nice.
Hi Guest!
What Morris said. This is not an unusual problem, I've heard of it before. Wish I could tell you exactly where the diode is, but you might have to follow the wires. My guess is it's built into a bullet connector somewhere.
