MGFever
I need a little more help guys. I've had a front end tire hop for awhile and have fixed the most obvious suspects and still have a problem. What happens is that at about 55 to 60 MPH the front end seems to be hopping . The wheel seems fairly stable but I have had several people mention that they can see it even at a low speed, say 40 MPH. I also noticed last night that if I give the wheel a sharp turn the front end wants to take off on me and it dives the other way almost to a point that I think I could loose it. /ubbthreads/images/graemlins/shocked.gif
So far, I have replaced the rebuilt shocks that were leaking with new rebuilts and I've upgraded to poly bushings. The front spindles seem fine and the previous owner had a receipt for a full kit although I can't confirm it was installed. I do have oversized tires on the beast.
When I had the front end in the air, I did notice a thump in the steering when I turned the wheel full rotation either way. Is this a possible issue with alignment or should I be concentrating on the steering linkage?
Thanks a lot for the advice.
