Hello,
I am ready to run my 1970 Midget off a cliff. I have replaced all wheel cylinders and the master cylinder and rebuilt the front/rear switch. I still cannot get the system to hold pressure (all lines are bled and all cylinders are braking). That is when the pedal is pumped all the brakes work but as soon as you stop pumping for a second the brake pedal then goes straight to the floor with no pressure - and as I said it is a new master cylinder.
Any ideas or experience is much appreciated.
Thank you
Thank you
