G
A few weeks ago I had a failure of my fan clutch, torerance ring, or water pump and the plastic fan the fan clutch went into the radiator. I posted this after it happened.
I now have a new water pump, fan clutch, tolerance ring, & plastic fan. I went to install the fan clutch onto the water pump and I found a difference between the old water pump and the new water pump. With the tolerance ring removed I can press on the new fan clutch onto the old water pump shaft with no pressure required. Is this normal? With the tolerance ring removed I cannot press the new fan clutch onto the new water pump. Is this correct? I don't know if the tight fit between the new fan clutch and new water pump is normal. Is there anyone out there who has replaced the water pump on a 1500 Midget? I would like to know if the fan clutch needs to be pressed onto the water pump shaft regardless of the tolerance ring. Thanks in advance for any help provided.
