Midget 1500 SU Carbs
blkcorvair
So I have heard time and time again that a nicely tuned pair of Su Carbs would be the best choice for the Spridget. On my originally equipped with the Zentith 1500 can this conversion be done. I mean obviously it can but are there manifolds available to create this combination? Of must it be fabricated. Im sure some entrepenuer has addressed this before? What are the better choice of SU's for this application. Car is running 9:1 with Nice Midrange Cam. Would like to get this thing on the track one day so hopefully my choice would be applicable.
racingenglishcars
That engine does very well with the european type SU carbs. That SU manifold is difficult to find in USA but England has many of them. The carbs might be difficult to get at cheap prices, but rebuilds are available and certainly a good way to go.
Otherwise the Weber DCOE is a very good way to go, with the proper sidedraft manifold. I have seen in the past single DCOE manifolds for the 1500. They might still be available and they give wonderful performance, even compared to the SUs.
tosoutherncars
Of note, you do need to *cut into the sheet metal in your engine bay* if you're going to use the common spitfire 1500 SU carbs & manifolds. I think there's a euro manifold that's a little shorter and doesn't require body mods. Surely someone more knowledgeable will chime in here...
-D
Morris
I think any 1500 dual set up on a left hand drive car requires the mod. On the euro spec cars, the brace that interferes with the carb bowl is on the other side of the car. It's the whole right-hand left-hand drive thing.
aeronca65t
You can also put a single 1-1/2" SU carb on your existing manifold.
Works decently....I've had it on a street car.
There are various SU carbs that are about this size.
The old-style H4 will need to have the holes slotted a little bit to fit. The newer HS44 will bolt on (I think).
I occasionally co-drive a 1275 racer with a single HS44 and it can pull about 110 mph.
Thor
I converted over to the dual SU setup on my 1500 a couple of years ago. I found it not difficult to do and think the dual setup looks great, performance is better and there is a lot of information available since the dual setup was standard in England.
You do have to cut a small area in the cross member and I also had to cut into the passanger footwell slightly as the fuel bowl was striking that it as well. I don't weld so ended up using epoxy. It turned out ok.
If you want I've got some information on the conversion with pictures on my website plus on some other carb setups:
https://www.visn2.com/BritishExperienceMidgetProject.html.
Go down towards the bottom of the page to the image with the engine and click on the carb setup. It will take you to the specific webpage.
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
K Midget 1500 Dual SU Carbs Spridgets 4
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
J 1500 mg midget fuel issue Spridgets 2
J 1500 midget master cylinder Spridgets 10
T ZS Question for 76 1500 midget Spridgets 33
T 76 midget 1500 oil pressure lines? Spridgets 15
frankenstang57 Educate me on the Midget 1500 MG 4
R Overdrive/5 speed options for 1500 Midget? Spridgets 21
P how to replace rear main seal in 1500 midget Spridgets 2
R pcv valve for 1500 midget? Spridgets 18
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
T 76 midget 1500 engine crud Spridgets 4
RickB Seat recovering, 1500 Midget Spridgets 18
R 1500 midget clutch inspection? Spridgets 3
R oil feed kit for 1500 midget? negatives in this? Spridgets 5
D Vacuum unit for 1500 Midget Spridgets 7
P holes in 76 midget 1500 front bumper Spridgets 6
R compression test procedure on 1500 midget Spridgets 5
G 79 midget 1500 clutch? Spridgets 5
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
bcbug Midget 1500 Hose Connections Spridgets 9
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
7 79 midget 1500 Emission Removal Spridgets 3
G 79 mg midget 1500 wiring Spridgets 7
bcbug 1500 midget carb replacement Spridgets 38
A 1300 cam bearings in Midget 1500 Spridgets 3
M 78 1500 Midget Tire Sizes Spridgets 1
J Midget 1500 electronic ignition? Spridgets 10
S 1500 Midget air intake Spridgets 1
S 77 Midget 1500 gearbox Spridgets 4
boxfullofyertoys Midget 1500 idle problem MG 0
boxfullofyertoys Midget 1500 idle problem Spridgets 10
