Midget 1500 electronic ignition?
Joelb
I was looking at getting a new distributer with electronic ignition for my 79 Midget. Does the 79 Midget come with electronic ignition? I am 7500 miles away from my car or I would check it myself.
Would I benifit much from installing a new distributer?
Howdy to Jack and Mickey, it's been a long time.
jlaird
Hi guy, thought you disapeared.
I would suggest that you need to check the old dizzy to determine its condition before jumping over the moon.
However, check with Jeff for a rebuild. He of course does excellent work for a reasonable price. In fact your old dizzy should be in top shape before installing an electronic unit as well. After 30 years your dizzy is ready for a bit of expert maintance in any case.
J
Joelb
Thanks Jack, I didn't dissapear, I'm just on an extended vacation in Afghanistan.
Morris
The '79 originally came with electronic ignition, but it was so crappy and unreliable that almost all stock ignition systems have been replaced. Soooo... you will have to send a buddy 'round to figure out what you have.
I agree with Jack's comments.
jlaird
In any case, welcome back. Hope you had fun :smile: I know you did, nothing like the real thing.
J
Joelb
Ahhh, if only I was back Jack, got a few more months in me yet!
jlaird
Ha, okies. Try to enjoy the time left. I know, I know you are away from your family but this is what you train for and work toward.
SAMidget
Down here in sunny Johannesburg
With reference to Jack's comments - I had my distributer (1977 1500) repaired and standard points put in. I then came across the electronic conversion kit and it took me about 5 minutes, including washing hands afterwards, to replace the old points. This was about 3 years ago and I have done no maintenace nor timing since. For the life of me I can't remember the name of the kit but it works like a charm.
I bought one of these ignition
have had no problems with this and the car has never run better.
mark
J
Joelb
I went ahead and bought a new dizzy with electronic ignition. I got the flame thrower model for a 1500. I also bought some headers and will put them all in at the same time so I can get the weber carb jetted correctly. Thanks for all the input. It will be a few weeks before I am home to install, but will post with results.
Midget78
Joelb, I did exactly what your going to do on my 78 1500. Runs like a champ and gets up to speed really quick. Kinda surprising.
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
J 1500 mg midget fuel issue Spridgets 2
J 1500 midget master cylinder Spridgets 10
T ZS Question for 76 1500 midget Spridgets 33
T 76 midget 1500 oil pressure lines? Spridgets 15
frankenstang57 Educate me on the Midget 1500 MG 4
R Overdrive/5 speed options for 1500 Midget? Spridgets 21
P how to replace rear main seal in 1500 midget Spridgets 2
R pcv valve for 1500 midget? Spridgets 18
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
T 76 midget 1500 engine crud Spridgets 4
RickB Seat recovering, 1500 Midget Spridgets 18
R 1500 midget clutch inspection? Spridgets 3
R oil feed kit for 1500 midget? negatives in this? Spridgets 5
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
D Vacuum unit for 1500 Midget Spridgets 7
P holes in 76 midget 1500 front bumper Spridgets 6
R compression test procedure on 1500 midget Spridgets 5
G 79 midget 1500 clutch? Spridgets 5
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
bcbug Midget 1500 Hose Connections Spridgets 9
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
7 79 midget 1500 Emission Removal Spridgets 3
G 79 mg midget 1500 wiring Spridgets 7
bcbug 1500 midget carb replacement Spridgets 38
A 1300 cam bearings in Midget 1500 Spridgets 3
M 78 1500 Midget Tire Sizes Spridgets 1
S 1500 Midget air intake Spridgets 1
S 77 Midget 1500 gearbox Spridgets 4
boxfullofyertoys Midget 1500 idle problem MG 0
boxfullofyertoys Midget 1500 idle problem Spridgets 10
tony barnhill Patriot 1500 Midget Headers Spridgets 3
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
