77_MG_Midget
After rebuilding the brake system, I bled the brakes and found a leak in the front. Ok, not bad, just haven't had time to fix yet. But, when I checked the master cylinder this weekend, it was near empty, both front and rear reservoir.
I don't understand why the back brake reservoir would be empty. They are seperate systems, split by the brake switch assembly, right? I have no leaks in the rear, so it must have leaked down from the front brakes.
Does this mean my brake switch assembly is not proportioning the system properly and is bad?
