Ola. First post here, and on what appears to be a hotly debated topic: Weber DGV on the 1275 engine. It's an interesting subject to me in as much as I'm surprised at how little technical information appears to be available on the topic. Searching this and other forums for tried and tested jet specs turns up almost nothing. Before spridgetmania.com evaporated (apparently they went bankrupt) I found a post on their site with suggested specs. Beyond that I've found a single post with suggested specs on The MG Experience. That's it. Otherwise most of what I find is opinion expressing how badly the DGV works on the 1275. And yet, I've also found posts from owners saying how great the DGV works on their 1275, but with no supporting technical info.
Does anyone out there have a DGV on their 1275, and if so, what jets are you running? Does it run well? The SUs on my Midget were driving me crazy with a constantly fluctating idle and generally very poor performance. I've gone through the steps to synchronize and set fuel/air multiple times. The result has been the same every time; a hard-starting and generally unevenly performing engine. Compression is excellent, valves are adjusted, timing is currently set at 10 degrees BTDC.
I already had the DGV, new and in the box from another project car (Volvo PV544) someone gave me (now gone), and decided to source a manifold and test the waters. At certain levels it's brilliant. It starts on the button and idles well. Cold starting on the SUs was terrible. Not so with the DGV. But, and of course there's a but, I'm experiencing the stumble on initial throttle reported by many. You can drive around it, but it's pretty obnoxious. I'm going to keep playing with jets, but I'd love to hear from anyone who's happy with their DGV conversion and most importantly what jets you're running. For the record, following are the two jet recommendations I've found and the jets currently fitted to the 1275.
Suggested Jetting SpridgetMania.com:
Primary Idle Jet: 50
Secondary Idle Jet: 55
Primary Main Jet: 135
Secondary Main Jet: 140
Primary Air Corrector Jet: 165
Secondary Air Corrector Jet: 160
Suggested Jetting MGExperience.com:
Primary Idle Jet: 45
Secondary Idle Jet: 40
Secondary Main Jet: 130
Current Jetting:
I went with spridgetmania's jet suggestions as a starting point. A first trial showed idle circuits too rich (fuel/air needle screwed out less than 1 turn), so I swapped the idle jets for the MG Experience suggestions. That improved the fuel/air setting (now at 1.5-.1.75 or so out), and seemed to improve throttle tip-in, but the stumble is still pronounced. The DGV is apparently sensitive to fuel pressure, which I've yet to confirm. That's up next, and I'll report what I find. In the meantime, I'd love to hear from anyone with verified results.
Current Jetting:
