RichBall
To get a rough idea of where they are, take your HS4 manifold and your new header and place them together as they would be if mounted. Where the center runner for your header sits between the two runners for the intake is where the bolts are. They are tough to see. You WIL NOT be able to get a ratchet on them at all. You will have to use a wrench and turn the nuts flat by flat. I don't think you will be able to get to them with the carb in place, but you can try.
Several of us are meeting today to work on our Spridgets. We will have a 1500 there, so I will see if I can get a picture for you.
Hi Guest!
