Mickey--Victor Question
PAUL161
Because the Victor is a replica of a TF, do you know if the grill is the same in hole position? Could you post a picture of the top of the grill where it mounts to the radiator? Is your grill steel or brass? A fella is having problems with his grill assembling from a basket case and it's possible it's not an original grill but from another car. I'm curious as many parts are interchangable from a Victor to a TF. PJ
Hey, Paul -
I'm away from the house until later - will take some pictures then.
The shell is steel, and the slats are different in that they are solid aluminum, so the mounting strip for them is different (though the one for my car is missing). Not sure of the mounting locations on the radiator, but will check when I get home.
