Bob_Spidell
TPMS works fine with plain old air (if that's what you're asking). The nitrogen 'fad' has come and gone IMO (and I'd bet most the cars with green valve stem caps are running plain ol' air; I have one).
Hi Guest!
The reason nitrogen alone is suppose to be more stable is that there shouldn't be any water vapor in it. Compressed air is usually saturated with it. Because water vapor isn't a "perfect gas", pressures will vary more than dry nitrogen (contaminated with oxygen or not).Supposedly, one advantage according to anciente wisdom was that N2 was more stable with temperature variations. Me, I don't think so: VP/zT=VP/zT . z is pretty close to 1 at atmospheric pressures, and none of the other variables actually vary a lot. If pressure goes down, add some of that there cheap N2 that's contaminated with 02 etc. The bulk of the air in the tyre will still be N2. Doug
Nitrogen is also a larger molecule so it leaks less.The reason nitrogen alone is suppose to be more stable is that there shouldn't be any water vapor in it. Compressed air is usually saturated with it. Because water vapor isn't a "perfect gas", pressures will vary more than dry nitrogen (contaminated with oxygen or not).
Not to change the subject, but what is that tool you’re using on the cylinder head?"I'll bet the Japanese engineers were upset when their Corporate let a bunch of Chinese engineers tour the factory and take pictures."
What goes around comes around. The Chinese are more protective (smarter than us?), but its manufacturing has been stagnating for a number of years and is now in decline. They are now losing manufacturing at a good pace to Vietnam, Thailand, Indonesia, India, Mexico and Brazil.
I met several fairly high-up Chinese officials at a dinner 7 years ago. They said they were trying to shift their economy away from manufacturing because of regional competition and severe pollution.
BTW, your Dad's restoration is amazing!
If you want to "reduce the gap" by lowering the rear end of your car you need to use lowering blocks between the spring and the axle housing.They do have me thinking about having my original leaf springs rebuilt and removing my replacement springs, just to lower the rear and reduce the gap between the tire and the rear fender opening. But that's another story.
Like the TR3a you can simply make longer rear spring hangersIf you want to "reduce the gap" by lowering the rear end of your car you need to use lowering blocks between the spring and the axle housing.
What exactly will you do to rebuild your original stock springs? New bushes?So rebuilding the original stock springs, which I still have sitting on a shelf, will lower the car
New bushes, new retaining straps (some of them are rusted out and I'm guessing the others won't survive disassembly), re-arch one of the springs so that they both have the same arc, bead blast the leafs and paint them before reassembly. That's what I'm thinking anyway.What exactly will you do to rebuild your original stock springs? New bushes?
You may be right. I don’t have them apart yet. But from what I can see the packing strips look to be in very good shape.You'll probably need new packing/friction material between the leaves. I believe original was zinc sheet, some use teflon strips.
