bill_powell
The install is progressing fine, but there is one issue I thought I would bring to your attention.
In my case, 1969 Midget, 1991 Miata seats, note the seat track:
There is an offset, circled in yellow. This is the passenger seat, with the offset on the outside track. No problem. Note that the inside track has no offset, so the mounting holes can remain within the Midget's reinforced area. I will be using the existing rear hole, and drill a new one for the front:
On the driver side, however, this offset is on the INSIDE. If you use the Midget's existing REAR/inside mounting hole, this offset will require either that the seat be canted right in order to keep the FRONT mounting hole within the reinforcing, or canted left to gain enough clearance for the bolt.
In my case, I decided to also drill the front hole within the reinforcing strip, and bolt a plate in (from the top, within the passenger compartment) with an additional, offset hole for a seperate seat mounting bolt. This allowed me to use the car's reinforcement, and keep the seat straight. (Sorry; I did not think to photograph the plate, and it was a PAIN to line up and tighten, so just go with your imaginations, if you would.)
Overall view at this stage. Using a wide-angle lens, so things are a bit 'bent' looking:
I know, I have a "black and tan" thing going on, but that's okay with me for now. Besides, I got the seats for $125, so what the heck. Off to work now; updates as needed/requested later...
