T-Series MGTD Fuel Pump Pressure
PlaidMan
Would anyone happen to know what the fuel pump pressure is for a 1952 MGTD? I'm considering installing an aftermarket type fuel pump and I know it should be a low pressure pump and hopefully I could purchase it at one of the local parts stores. Thanks, Charlie
2.5~4 PSI. The metal "cube" Facet pumps should work. NAPA, etc. Carter has an in-line "lift pump" meant to be submersible I've used with success too. Part number P60504. Low pressure.
