MGB MGB VIN number?
mmotors
I have a MGB VIN number GHN3L19031, body number 018712. This would be a 1963, right? The PA title with the same VIN number has it listed as a 1966. How could this be????
Thank you.
mmm.... typo?
...or sold in '66 after sittin' at Royston for a couple years?
'tis a bit of a puzzle.
In those days, cars were registered when they were first purchased....could've been sitting around on the lot like Doc said...easy to change year on title.
Just for curiosity's sake, what's the engine number? It'll be on an aluminum "tag" blind riveted to the block just below the head on the starboard side.
Unfortun. is was removed at some point. Certainly not a 66'- pull handles, Ft. crank case breather, etc. What is Royston?
Rats. How 'bout th' "clock" in the casting?
Pull handles MAY have been on *some* '66 cars. Early ones.
Royston was the east coast distribution center for BMC back in the day. Acres of cars and parts.
There's a date stamp cast into th' blocks. IIRC it'll be low onna starboard side, just forward of the dipstick. Has a slot-head screw in relief at the center of the thing.
The only numbers I could see with the engine in the car (light and mirror) under the gen and in ft of the oil filter is 2B4B and I70? or 17D? Hard to tell if a I or 1 and 0 or D. No screw though. Does the filter need to be off to view the date stamp. Thanks, Shawn
Yup... The "clock" is almost DIRECTLY behind the cannister. A small nirror on a stalk would be a better way, tho. Much less messy. :wink:
