It does this when it's cold from a first start.
Tachometer seems to be cutting out (never gets to zero before bouncing back up) and the engine does to.
The same time this began also I noticed it would not start by the first few seconds, some times it takes two or 3 tries before starting.
Once the car is fully warmed up it hardly ever does it again.
I've checked:
coil connections, no wires are touching each other externally.
cap, rotor, points, plugs all look good.
I have a gold lucas sport coil....possible it's going south?
thoughts?
I've checked:
thoughts?
The points gap was always a matchbook task in the old days if ya got caught out without your feeler gauges... 0.015" or "close enuff fer gummint work!"
