I'm still sorting out items on the 1977 MGB that I bought awhile ago. The latest is a heating problem at 55+mph. Background. The motor has been rebuilt with the block and head cleaned. The radiator was repaired and refurbished. All new hoses. I can drive the car at 45 to 50 mph with it running a normal 180 to 190. When I go on a short trip of 10 miles at 55+ the temperature climbs slowly up to 210 after about five miles. I haven't let it get any hotter because I slow down in order for the temperature to drop down. The radiator has not boiled over and the car is running fine, just the temperature keeps going up. I replaced the temperature sending unit with an original out of an extra motor. Then I installed an aftermarket gauge that has the exact temperature indicated. I have replaced the thermostat from a 180 to a 160. Nothing changed on the heating. I took the thermostat out and put the brass sleeve in which has small holes in the side of it and is, basically, a straight through tube. Same heating. Some suggestions are a new distributor or an oil cooler. I haven't been able to check the timing yet, but will soon. I use non ethanol high test gas.
If someone has had this problem, please let me know how you fixed it.
Thanks,
Charlie
Thanks,
Charlie
