Sebring222
I recently swapped rear axles on a BGT, tube type, and decided to try Royal Purple gear lube. I took the car out a couple of times on short trips to verify that there weren't any problems and noticed a leak. It was a simple matter of re-torquing a bolt and the problem was solved. While doing this I happened to place my hand on the diff case and found that the case was really pretty hot to the touch. Over the years I never really noticed what the diff temperature might be. Is it normal for the differential to run somewhat hot? By hot I don't mean overheated radiator hot, just somewhat hot to the touch.
