Parker
Hi. I have some of the Roadster Factory's best BMH trim strips, but need advice on installing them... I've used their installation kit and have riveted the "cups" into the old mounting holes, leaving a single large hole at each panel for the screw-in brackets. However, when I try to slide the trim strip in order to feed the first cup into the widened part of the mounting slot, the cup just won't slide into the trim. I don't want to force it and either scratch my new paint job, or bend the strip. I tried a little paste wax to lubricate the slot in the back of the trim, but no luck. Is there some kind of technique that has worked for anyone out there? Any advice would be greatly appreciated! Thanks, Parker
Hi Guest!
