rick_ingram said:What pressure does the engine run at idle as well as at speed after it's warmed up?
ronzet said:Arky_1,
When you start it up when cold what does the OP read at idle?
Also, in the first 15 minutes, what is the OP when you are driving the car?
And, the OP stays at 10psi whether idling or driving? [/quote
When cold idle 40 to 50 psi, first 15 minutes driving will the first 10 minutes 40 to 50 psi then drops 10 psi then stays at 10 psi whether idling or driving correct
tony barnhill said:Well, before anybody suggests he jump in & start disasembly, there are still lots of questions to answer - & as he's new to MG's, we need to go slowly on this one.
Some good questions already posed...let's summarize & answer these in order:
1) what type oil is in the engine (20w50, 10w30) & how long's it been in there?
2) what's the oil pressure when first started - idling & at speed?
3) what's the oil pressure when the engine gets to normal operating temperature - idling or at speed? [think that's been answered: 10psi idling or at speed]
4. what's the compression - taken dry & then taken wet?
5. can you do a "leakdown test"?
There may be more, but that's a start.....
Castrol 20w50 - & they have it for engines with lots of miles on them.Arky_1 said:tony barnhill said:Well, before anybody suggests he jump in & start disasembly, there are still lots of questions to answer - & as he's new to MG's, we need to go slowly on this one.
what type of oil do you recomend?
Absolutely nothing - except, I'm gonna bet there's an engine teardown in his future & it'll let him know a little more about the condition of his head & rings - especially if he has to repair the main problem on a tight budget....& I just like to do all the tests possible before tearing one down!ronzet said:Tony,
Since I am always interested in learning something new, especially from a Guru...
Please elucidate me to the relevance of #4 to the symptomology..
Both are possibilities...however, I figured adding them to his questions to answer right now could complicate things as they're probably gonna ID the problem.....putting a penny behind the pressure relief spring will tell if its the problem; switching guages temporarily will also...but, if you're new to the hobby, I figured "KISS".ronzet said:A bad gauge is certainly a possibility. Another possibility is a faulty oil pressure release valve....
