DrEntropy said:I figger you've got a 3.9 if you followed that guide. Well done!
...see?!?! Wazzant simple? :laugh:
Tube axles were installed on all cars starting in 1966 and were unchanged throughout the end of production. Ratios for all MGBs 1962-1980 was 3.9:1. Only the axle changed, never the gearing. The gears themselves are not interchangeable between banjo and tube.tdskip said:Check me to see if I got this right, as a Salisburg axle it would have been used on later cars, starting with the BGT right? Did the ratios vary in Salisburg axle or where they constant through the production run (can't imagine they were constant)?
4.1 and 4.3 were standard for MGA.tdskip said:Do you know off hand what a stock MGA would have been?
tony barnhill said:3.9 pretty standard for MGB's.
