Dan_Willert
After replacing bearings/spline hubs on all four, rear brake shoes started to seriously drag and heat up. Adjuster is all the way down and still had a tough time removing the drum after cooling down; still hard to get back on over shoes and wheel will not turn. One note; I did hear and feel a weird noise on the parking brake when I pulled it before I set out on the test run. But the cable appears to be loose now. Hydraulic lines seem to be OK. Never touched the master cylinder. My next step (since I'm out of ideas) is to perhaps bleed the system?
