Hi All,
Just trying to trace an annoying engine rattle. The car has been laid up for 18 months. Hopefully the attached youtube link works but the rattle, difficult to hear, happens at light to hard acceleration. Other than that the engine works fine and has done for a number of years.
I first looked at pre ignition so tried the timing at various points at 1000rpm from 2.5 - 10 degrees.
The fuel tank has 97 octane fuel in it and has run happily on it in the past
The timing advances to 20 degrees at 4000rpm, so I have ruled this out for the time being although I am aware that I put a new electronic distributor on before the car was laid up so may come back to it. The engine is a 1622cc with some mild tuning and has run perfectly well up untill now.
The rocker shaft clearances were all good.
The head gasket and clearances were good.
Compression 200-210 PSI on all cylinders when hot, 217-232 with oil squirted in the bores when hot.
Oil pressure is 60 PSI when running and 40 PSI when hot on tick over.
The car has had a rebuilt gearbox fitted and the rattle was there before and after.
I am in the process of stripping the engine down and have found.
The main bearings are good as is the oil pump.
The cylinder bores look good with no steps at the top.
Camshaft end float is .012" so will need adjusting. The camshaft is halfway out as I need to jack the engine up a touch to get it out the rest of the way but the half that I can see is OK.
My next job is to pull the pistons out and check the big ends, little ends (wrist pins) and the rings.
Does anyone know of anything else that I need check while the engine is in a thousand pieces?
Kind Regards, Martin
Hi Guest!
