MGA MGA 1600 - Honda K24 swap?
Samizdat
Has anyone seen an example of a Honda K24 swap into an MGA?
1961 MGA 1600 MK I if we need to get specific… I have a good roller, but it has a seized engine.
Before you tell me there are better option out there, the reason I ask is that I may have come into a K24 donor at little to no cost and I’m trying to decide what to do with it.
I like the idea - I'd do some measuring to see if it will fit. I looked at an MGB that had a overhead cam Nissan engine (SE 20 I think) swapped in but making it fit meant they had to notch down the front crossmember a lot more than I felt comfortable seeing, so I passed on it. If the K24 will physically fit into the MGA's engine compartment without compromising structure it would be a really sweet upgrade power-wise. I have no idea how it would get connected to the MGA transmission, you may also have to use a matching Honda transmission so check the space available for that as well.
