Terry_Geiger
I'm tackling some work on an MG TC. I've never replaced King Pins on this particular car before. Do the king pins install with no machining or do you need to have an appropriately sized reamer to fit them to the bushings? Do the bushings press fit by hand or will a press be needed? I'm trying to determine if I need to pull the front hubs from the axle or if the job can be done in situ.
Input from someone that has been there and bought the t-shirt would be greatly appreciated.
