lesingepsycho
I was at the annual British Field Meet at PIR here in Portland this Labor day and while I was there I had my eye on a used Mallory dual point dizzy for relatively cheap. I talked to the guy for a while and he told me that there was a Datsun or Nissan or some sort of asian pickup truck distributor that was a direct replacement for the lucas so I wound up passing on the Mallory but now I've forgotten what the substitute distributor was and can't find any info on the web. /ubbthreads/images/graemlins/frown.gif If anybody out there knows about this, I would like to replace my dizzy with something a little better. I currently have the stock lucas with a shot vacuum unit and now I can't go with the mallory because it isn't compatible with the MSD-6AL ignition box I'm using (although I'm told if you just remove the trailing set of points it will work. Still, it's a bit expensive for the application). Any info will be greatly appreciated.
Hi Guest!
