TR4A has been sitting for 25 years. Changed oil...fresh gas..fired up engine and runs fine. I'm going to go thru the clutch hydraulics first and drain and refill the gearbox. I was planning on pulling the trans in situ to check out the clutch but now I'm thinking I might just try freeing the clutch up.Might still be functional as the engine sure was. I'm assuming it will be stuck after sitting for so long. What was the procedure for freeing up the disc from the flywheel.
