blkcorvair
Anyone got an loose HS6 Carb handy that they can take a measurement on? I just need the overall length, from gasket surface to gasket surface. Thanks
Adrian, LOL The way I know it, and some of this is true knowledge, and some may be interpreted, but:bigjones said:Peter,
Wow. You are quite correct, of course. Thanks for pointing that out - hope I didn't cause confusion. What is the difference between H and HS, anyways?
As for the gopher, well spotted. Maybe that is the cause of funny noises I hear under the hood?
Cheers,
Adrian
PeterC said:Thanks Roger. I figured there had to be some.
Oh, I forgot, the number (4, 6, etc) in the case of these carbs, is he number of 1/8s eighths of an inch over 1" of the butterfly bore. So in this case 6 is 6/8 or 3/4" or 1-3/4.
The HIF44 are 44mm or 1-3/4"
Peter
rick_ingram said:Cool bit of trivia!
And...the HIF44 (now being touted by Moss and Vicky Brit as a bolt on replacement for the ZS175 for the RB MGB) is very similar to the HIF6 that I used on my 1978 MGB back in 1992.
PeterC said:rick_ingram said:Cool bit of trivia!
and a ZS175 = 1.75" and a ZS150 = 1.50"
In case you didn't know.
Peter
