TR6 Maximum overbore
charleyf
What is the current thinking of the maximum over bore on a TR6 (1972)engine. It is presently bored at .040 over and needs to be bored out yet again. I would guess that this block is near the maximum, but don't know.
Charley
TR3driver
Great Pumpkin - R.I.P
I don't know either, but sounds like it might be time to have it sleeved back to standard.
glemon
I don't know either, but manufactures will generally only make pistons/rings to maximum overbore size, so checking some catalogs might be helpful (and if you can't get the proper parts for the overbore anyway...)
glemon
I am too lazy to do the math, but last time I did I seems to recall that an .060" overbore adds a little bit of displacement to the motor, more than a couple of CCs anyway.
charleyf
charleyf
Thanks for all of the input.
It looks like we are going to explore the "other" option of trying to find a replacement block.
Anybody know of a 72-76 TR6 block located in Northern Calif or Southern Oregon? Preferably with standard size ( no overbore) ?
Charley
Deleted member 8987
Core Shift. Not sure if TR's had the issue, but it can limit (or increase) amount of bore.
Machine shops can check through water ports to outside on cylinder walls from bore surface.
One of the engine designs I work on can go 180 with no core shift.
Oddly, some of the ones I have worked on came factory sleeved. Knock worn sleeves out and none, it's .o83" over, and they make (made?) pistons and rings that were.....083" over.
Longevity-wise for you, if it takes more than .020 to clean it up, finding slugs bigger without using Egge Machine (if they're still around) may be a trip.
My Jag was .040 over, had broken rings, slugs okay, power honed okay....but nobody had .040 rings for it. Did .060 rings, gapped the ends, runs fine.
