JohnBazzano said:Auggie'
I'm with John and Darrell on this.
When I seperated my inner fender from the body tub, for the first time since new, on my '54 TR2, I found the same material and also noticed the parts were unpainted beneath that compound. I simply removed the material, primed and painted with the thought of easier removal if necessary later.
I actually never drive on wet pavement anyway so that area never sees water.
Bear with me if you would please, I'm not sure I understand what goes where here. The inner fender is welded to the tub, I believe. The outer fender is bolted to the inner, to the "A" post and to the front apron.lbcs_r_fun said:JohnBazzano said:Auggie'
<span style="font-size: 12pt">John: Are you the original owner of the TR2? The reason I ask, it has never been established that Triumph used any sealer or dumdum between bolt-on panels and the body tub, at least not on the sidescreen cars. Yet, from time to time we hear of this.
I believe that sealers actually work against you by trapping water and preventing these small areas to dry properly. </span>
lbcs_r_fun said:The cars left Mulliners with the wings loosely bolted on and the interior fully trimmed. They arrived on temporary chassis. I have seen photos of this at BMIHT in Gaydon. The consensus is that Canley did not apply sealants. However, one of the pre-delivery checks was to determine if the cars were sealed properly. The details of this operation were never really explained. It has been suggested that some cars were sealed by dealers or POE service agents.
