I am rebuilding the drum brake dual master cylinder with the Moss kit (180-970). The main seals and washers fit the bores correctly. The secondary seal is to be stretched over the piston and then slid into the bore.
The pictures show the seal over the piston; I believe it is properly seated. The diameter is a good 1/32" greater than the bore. Do I just force it into the bore? I am afraid it will be so tight the spring won't return the piston. Have I done something wrong?
Jim
Jim
