jvandyke
jlaird said:Jacks trickie trick. Get a short peice of pipe or tube or. slice it lengthwise on one side. Back off the adjusting nut just inside the tranny tunnel, slip your new spacer over the cable, retighten the nut untill you have the brakes adjusted properly.
About half inch would be about the right length I should think.
Gota think outside the box on some of this stuff.
I'll look into that. This is to address a stretched cable or something? When adjusted it wouldn't really effect the hydraulics though would it?
Hi Guest!
