jvandyke
So I waited on yet another master cylinder kit and rebuilt yet again and now it's worse! Had a good feeling pedal during bleeding, took off for a test drive and by the 2nd time I hit pedal (to slow down for the end of the driveway) NOTHING. All the way to the floor.
I guess I'll tear it down again to see what happened then it's off to Whitepost or someone for a bore and sleeve. Unless you think a 7/8" would be an alright replacement?
Am I missing something? I can pump it back and get some braking but it only last a push or two then nothing. Air somewhere wouldn't have those symptoms would it?
At least the car ran GREAT after the tuneup. Man what a difference, too bad I can't STOP. Wow am I bummed. Oh well.
If it's a hole anywhere but at the outer edge then something else is poking it in there. If the bore is rough enough to tear or damage the cups that quickly then it would be quite obvious to the eye. My Sprite is nowhere near that point yet so I am just speaking from many years of general experience rather than spridget specific. But I'm sure the principle still holds. The reason they went from 7/8 to 3/4 was to reduce the pedal force required with the disc brakes as it takes more force to operate the discs than drums. finally, I'm not certain but I think the clutch cylinder stayed the same with either brake master. As an aside, Some time ago, I changed my wife's Super Beetle to front discs without changing the master and the difference in pedal is really not noticeable. I still think you will feel a 1/3 increase in required force though.
:banana: !!! re: hope it lasts a while...it will! at least until a little air softens it (eventually!), but it sounds like even with that, you are ahead of the game with that set-up! Have fun!! :thumbsup:
