T-Series Master Clutch Cyl. Rebuild Kit
kbash
Well I'm about to order a Master Clutch Rebuild Kit. Unless some one has a spare non used one layign around. That the onlky thign I'm worried about on the 11th is the Master Clutch Cyl.
Are either of the cylinders (master or slave) leaking? If neither one is and your clutch engaged/disengaged fine before your car went off the road, I can't think of any reason to rebuild them.
However, if you rebuild the master, rebuild the slave as well and vice versa.
I've gotta do mine this spring....got the kit ready to go!
