Okay, I know we've discussed this before, but I was a bit confused then. I'm a bit confused now as well.
Due to some bad notes on my part (and the fact that it was over a year ago), I'm not sure which way my dizzy was set up when I had Jeff at Advance rebuild it. My carbs and manifold both have the spots for pulling vacuum. I *think* it was set up to use manifold vacuum, but I'm not sure.
Is there a good way to test and see which way it is is set up? I tried to call Jeff at Advance this morning, but they're closed until Monday. I'd like to do some tuneup work this weekend, and need to make sure the timing is correct.
The engine *seems* to be running properly with the vacuum from the manifold, but I don't have enough experience to know if it is *really* running correctly. Essentially, I don't really know what "correct" will be like.
