Ran into my first problem removing head. At least 2 exhaust manifold nuts are blocked by the intake manifold - in fact one of the studs is coming out with the nut. I unscrewed the 3 long bolts at the top of the intake manifold - they are loose but complete removal is blocked by the carbs but they'll slide out with the manifold removal - but there must be more bolts or nuts holding the intake manifold because it won't budge when I try to lever it off. I see a little give at the top which leads me to believe that there are more bolts on the bottom. I looked at the Roadster Factory manual but it doesn't show how many bolts there are. My question is: how many intake manifold bolts/nuts are there and what's the best way to get at the bottom ones that I assume are there?
