T-Series MAKING COPY OF IGNITION KEY
Check with Triple-C to see if they have the correct blank. Their website says they're closed in February. Once you have a blank, any business that cuts keys should be able to cut the duplicate using your original as the pattern. Peter Groh used to sell original keys, but I don't know if anyone picked up that business.
Hi Ray - welcome to BCF. I had my local key shop (not Home Depot!) make dup's of my 1953 TD key. No problem. It wasn't an original blank. Also, Moss Motors has MG keys:
You might want to post MG specific questions in the BCF MG forum here:
And non-specific questions in the Pub:
Hope this helps.
Tom M.
Thank you for the information. aloha from Hawaii
Hope this helps.
Tom M.
Thanks for the help. appreciate it very much.
Hi Ray, you posted your question in our Forum Navigation section which is intended as a place to ask questions about navigating the site. I'm moving your topic to the MG forum. If you're reading this, you are now in the MG forum.
Cheers,
I picked up that business from Pete. You can reach me at jake@britishkeys.com
