jmwuva05
Note before I started this restoration this car ran perfectly. I have already checked all the points etc and I am sure they are correct. I have followed the procedure for setting static timing in the manual exactly. Still no fireing despite multiple attempts at rotating the dizzy body. I was wondering about the 180 degree out possibility. When I try to insert the drive spindle 180 opposite the centrifigal weights wont engage they only engage in one position. Also concering the positioning of the rotor cap, should the portion of the cap with the metal curve be pointing at the position of the #1 plug wire or vice versa? Any sage advice appreciaed.
