MacGyver !!
Moseso
The scene: A stop-and-go freeway in the middle of downtown Minneapolis, ca. 5:30 PM, yesterday.
The symptom: My accelerator pedal no longer returns to the position where I am accustomed to finding it with my foot. There is still <span style="font-style: italic">some</span> connection to the carbs, but not much. Flooring it might get me to 30 mph. Bummer!
So -- I exit at the next opportunity and pull to the curb at the first possibility, fortunately within 2 blocks of the exit ramp. Up goes the bonnet. I operate the throttle from the front carb and note that the lever that should be pinned to the pedal shaft is moving rather independently of the shaft. The cotter pin I had used there is sheared. I feel around underneath -- just a hole. On top, there are the two legs of the cotter pin still sticking up.
So, I get out my Leatherman pocket pliers and try to stuff the remaining bits of pin down into the hole for about ten minutes. No luck. Then, I try to extract the remnants of the pin, losing half of it in the process. Using the flashlight from my cubby box, I am able to more-or-less line up the holes in the lever and shaft and, using the pliers, finally drop the remaining 1/2 cotter into the hole. This strikes me as not-quite good enough to get home. I need to keep that pin in the hole somehow. Not really knowing what I'm looking for, I return to the cubby. EUREKA!! There is a little velcro strap, given me by a hand therapist last summer, in a vain attempt to make my finger stop hurting. Called a "buddy strap," it's used to lightly bind one finger to it's neighbor. I wrap this around the collar on the lever (freakin' PERFECT fit) so that it covers both holes, trapping the pin remnant in place.
Then I drove 15 miles home and parked in the garage, where the car shall remain until I can make a proper repair.
Total elapsed time from deciding to exit the roadway to making the u-turn towards home, about 40 minutes. Hands: still somewhat dirty, of course.
Moseso,
Both sets of throttle linkage that came with my 59 3 had bent nails in those holes.
Whats the proper part?
Tom
It should be a Mills pin, part #500555.
Apparently the cotter I used is a little soft for the job. I only got about 11,000 miles on it. Part of the problem may come from toeing the pedal up, to drop the idle speed at signals.
This will provide me an opportunity to see if I can lube the shaft a little better to reduce the need for that.
Moseso, you are my hero.
I am honored, John.
I've always owned "beaters," and fixed 'em myself. While it's never a good sensation when the car fails in some way, out on the road -- it's a bunch of fun to get one home like that.
The scariest one was way out somewhere in the North San Francisco Bay in a little boat my neighbor had borrowed so we could go fishing. When we wanted to call it a day, the little outboard motor was having none of that. Would. Not. Start. After a while I said, "let me try this..." I checked for fuel: yes. I pulled the plug wire -- no spark. I popped the top off the thing and looked inside. There was something about the ignition points (I know longer remember what) that looked distinctly broken. Some rummaging around in the tackle box yielded something (again, I forget what) that served to repair this thing well enough to make it fire, employing only a fishing pliers and Swiss Army knife for tools. We were about an hour from the landing -- it ran all the way. My neighbor couldn't stop talking about that one for months!
Just adding a couple of cotter pins to my box of goodies in my boot.
Eric --
That one is 1/8"
:smile:
I like to read those '50s Popular Mechanics short, maybe two paragraph with a drawing, articles that are entitled "Discarded X Used to Repair Y". Or "X Made from Discarded Piece of Y."
Just makes me feel good for some reason.
