Lug nuts
John_Mc
I noticed recently, much to my dismay, that one of my lug nuts is missing. Are these a specialty item, or is a similar item available through the local parts store? It's a '71 TR6. Thanks.
If they are original lug nuts, you will have to go through one of the Triumph parts distributors.
Speaking of lug nuts, since I have Panasports on all four corners and a stock steel rim in the trunk for a spare, I carry the four stock lug nuts in a little sack on top of the spare as the lug nuts that came with the mags are different from stock. A little "did you know...."
If I had kept the other lug nuts, I would have sent them to you.
Bill
A generic lug nut will work on the wheel. The stock unit with the plastic washer(I believe sold separately) are used so not to damage the wheel center.
