sp53 said:Does the actual size of a Lucas Sport ignition coil matter? I purchase one about 10 years ago. It stated to be 40,000 volts and one last week is considerably smaller and does not make the 40,000volt claim.
steve
regularman said:...I need a ballast resistor for my other midget the 1500 with the spit engine, and I am not sure what resistance it needs to be...
Thank you for the offer. I was able to take some time and dig in there today and figure things out. It turns out that the car never had a ballast resistor but a ballast wire. They ran a pink/white stripe wire out in the harness near the headlights then attached it to the wire going to the coil and then ran that wire back near the firewall and attached it to the white(run +12v from ignition). I got it sorted out and have 12v at the coil when starting and 6.5v when running.Geo Hahn said:regularman said:...I need a ballast resistor for my other midget the 1500 with the spit engine, and I am not sure what resistance it needs to be...
I've got this one which you can have for the cost of shipping (though it may be cheaper to just buy local):
