Lucas Sport ignition coil
sp53
Does the actual size of a Lucas Sport ignition coil matter? I purchase one about 10 years ago. It stated to be 40,000 volts and one last week is considerably smaller and does not make the 40,000volt claim.
steve
I guess that it only matters if the 40K volts is important, as if you were to widen your spark plug gap.
I guess I've only seen the one size -- is the old one larger than a stock coil or is the new one smaller than stock?
I have a device that measures ignition voltage, though the scale only goes to 30000 volts. I should try it and see if the sport coil pags the needle.
New Sport Coil
"Real" Sports Coil
I don't know if the "real" ones were any better than the modern, new ones...but they sure looked much cooler! :smile:
I agree, that high tension fitting just screams 'Buck Rogers' Ray Gun'.
<span style="font-style: italic">Of course you don't have to live with that white & gold color scheme...</span>
I love sports coils, they really come into their own as you pass 15,000 rpm, but otherwise the faster rise time can be a nuisance in that your spark may appear somewhere less useful than at the plugs with consequent failure. Widening the plug gap increases the risk, usually for the rotor arm.
Therefore I use a 12 Volts general purpose ignition coil of the highest primary resistance I can find. One that takes so little current that you can hardly see the ammeter move when you turn the ignition on. I run a Healey 3000, a TR3A and a Bentley MKVI this way as I have my cars since th sixties.
Ash
EV2239 said:
I love sports coils, they really come into their own <span style="font-weight: bold"><span style="font-style: italic">as you pass 15,000 rpm</span></span>,
I assume that's a slipped decimal point.
Oddly enough, with my Lucas Sports coil, the engine won't turn past 150 rpm.
Oddly enough I have had the gold sport coil fail suddenly after about 8 or 9 years of use.It seems that the engineers at Lucas have found a way to only load a certain number of sparks into these units before they are empty!!!Carry a spare!!
MD(mad dog)
I am sorry for not being clearer. The two coils in question are like the first one in Andy’s picture. The one I purchased last week is about 10% smaller than the one I got 8 years ago. The box and coil look the same. I guess they could have used smaller wirer in the winding of the wire, and still got 40,000 volts. I love those old stock coils. I had two of them, but they both failed. What coil should I use on a stock tr3? Geo is that an old one or new one.
Steve
No apparently not, the benefit is after about 15,000 revs!
I've had four Lucas ignition coils fail in the last couple of years and all have caused major inconvenience.
Two emptied their oil out and failed (they are terminals down on a MKVI) one failed on the Bristol and I had to go home on a trailer and then another failed on the Bentley despite being the right way up. The reason for the last two to fail was that although they were labelled as 12 volts, they were drawing far too much current because they were 6 or intended for a ballast resistor.
Now I avoid Lucas if I can, they aren't Lucas any more anyway, they are American owned I believe and the stuff is sourced from all over the place.
The risk with sports coils is that the spark builds up more quickly so arcing other than at the plugs is more likely. Most don't have problems, but if you have rotor arm problems, it can be sports coils.
Ash
Maybe that's the problem, Ash! The current owners of the Lucas name are trading on it rather than (no snickers, please) doing anything that would actually maintain the reputation they had (stop laughing!) for some pretty darned good quality parts. In over 40 years of driving Triumphs, I've only ever had one coil fail, and that was back in the early 1970s on a Mk3 Spitfire (ok, now you can chuckle a little if you must). But my current driver '62 Herald is still running just fine on its original coil! On the other hand, I might find out in the coming months how good the current "Lucas brand" contact points sets are....
I've been saying that for years : Not all "12v" coils are intended to be used without a ballast resistor. In fact, by far the most common style available in the USA is "12v ballast required".
And Lucas Sports coils do come in both flavors (no ballast vs ballast required).
Ken Gillanders (British Frame & Engine) once wrote for the club newsletter that he had gotten in a case of 12 new Lucas Sports coils. Put on a coil tester, over half of them were either totally dead, or did not work right!
The one I bought at TRfest 2009 failed a few months ago.
And as Andy points out, "Lucas" is just a name that has been sold and re-sold many times in the past few decades. Last time I checked, there were something like 6 or 8 different companies that had the right to use the Lucas name in one area or another!
So, just like modern Minis, any resemblance to the original product is purely coincidental.
Steve
Something like these,Steve ?
It may have had a sticker, but it is the same size as a properly "engraved" DLB 105 that I recently gave away.
