TexasKnucklehead
Just to be clear, when I made my new brush spring retainer, I used the plastic from the peter pan lid, not the cardboard. Since then, I made three more out of different materials. First I used a "break-away" (fiberglass) from a printed circuit board, but it had Vcc/Gnd planes between layers and was not a good insulator. Then I made one from some clear lexan, which might work, but I thought it was about as soft as the plastic lid. Then I made one from "call grade formica", thanks to fellow member Moses. I used a dremmel cut-off wheel placed into a drill press to cut the tiny part. I also replaced the spring. I think it's about as good as new now... aside from the brush wear. (spec says it should draw from 2 to 3.5 amps, and I read 2.7v across 1 ohm.) Thanks for all the input.
Jerry
(I think this is actually a TR4 assembly, because the TR3 doesn't have the "limit switch" -the stainless steel cover shouldn't even have a hole for the raised cover.)
Jerry
