Thank you for your reply about location of the pump. It is possible someone changed the tank etc in that past. Currently I do have a pump in the wing. I am trying to solve a long running problem which has now been isolated to fuel. Only when the engine is very warm, it starts to miss due to fuel leaning out. Carbs are all fine and actually not overly warm. Fuel lines are not overly warm either so it is very doubtful it is vapor lock of some sort. I am trying to see if the fuel pump is simply not supplying enough fuel but again this only happens when the engine is hot. I have now had 3 pumps in this car, the first two were Facets and both failed.
XK's reply
Your email was forwarded to me for review. Is the car still positive ground ? If yes to go with the original may prove costly as you would need to purchase the banjo bolts and related pieces. I have listed the positive ground replacement pump along with the negative ground version in case your vehicle was changed over the years. All of the pumps are available at this time. Thanks for the inquiry.
Best regards,
Daryl
