twas_brillig
The flasher unit recently failed on our BJ7, and I ordered a replacement from AH Spares. It wasn't an exact match but buddy Jeff installed it and everything worked. However, looking at the original (maybe from 1962; maybe later, but it had Lucas stamped on the exterior which the replacement did not), it appeared that we could maybe swap the internals around.
And Jeff successfully made the transplant this afternoon, such that we now have the flashing internals (about half the size of the original) installed inside the original casing. Relatively simple, as the retention of the internals is strictly mechanical and you spend a bit of time prying the metal contacts holding the 'base' in, and swap the bits.
A minor touch, but worthwhile, we think.
Doug
PS: don't be lazy/stupid like I have been for years: adjust your mixture. Jeff did so a month back (after years of running rich) and she sure runs a lot better.
Doug
