Deleted member 12902
Good afternoon fellow Healey owners. I am having trouble installing the lower wishbone rubber bushings in the car. When the bushings are in place and I start to tighten the bolts & nuts with the cut-out washers, the nut and bolt get tight but the cut-out on the washers still isn't seated into the anti-rotation tongue on the mount. It acts as if the bushings are too long and the steel inserts in the bushings are coming together before the bushings are seated. Any guidance would be greatly appreciated.
Pete D.
Pete D.
