My new to me BJ8 has 20 psi at hot idle and 25 psi at hot running.
Cold idle is 40 but once warmed up it is down to 20
Oil is Mobil 1 15/50 synthetic
Oil filter is stock
Miliage is unknown but I suspect approx 110,000 miles
Just back from a 800 Km trip and it consumed 1 liter of oil which seems a bit excessive.
I have been reading about worn rocker shafts and related low oil pressure issues. Will pull the valve cover and take a look when running to see if this is the problem
Also reading on this forum about the oil pressure releif valve is this not for excessive pressure by-pass.
After all it still has a lot of miles and an engine rebuild may well be required. Any good Healey rebuilders in Vancouver Canada.
Oil filter is stock
