johnjoan6203
just finished with major rebuild on 1973 MGB, new pistons 020, main and rod .010, new oil pump and strainer ,new oil pressure relief valve, new cam and bearings,double row timing gears and chain, now for the head all new valves, guides, springs, seats, new push rods , new lifters , new pressure plate, clutch, release bearing, only have about 50 miles on this rebuild ,oil pressure is low at idle between 15-25 psi.when warm going down the road its about 65-75psi at 3000 rpms,Is this normal /ubbthreads/images/graemlins/confused.gif
